Mersen’s all new M-series disconnect switch product line provides customers with a product rich in long-term safety, reliability, functionality, and a newly engineered smaller footprint. Mersen M-series disconnect switches are available in three types: fusible, non-fusible, and load break.
Mersen’s M-series Fusible disconnect switches are listed to UL 98 and are engineered to have the smallest footprint. They are service entrance devices capable of fully rated load-break and load-make. Mersen fusible disconnect switches provide a modular design allowing for placement of the handle anywhere amongst the poles. Fusible disconnect switches are double-break, isolating both fuse clips from voltage during fuse replacement. The switches “Test” position allows actuation of the auxiliary contacts without main power. Power taps enable energizing a CPT or surge device without the need for a separate terminal block. Mersen fusible disconnect switches are available in 30A to 1200A frame sizes.
M-series Non-fusible disconnect switches are listed to UL 98 and are service entrance devices capable of fully rated load-break and load-make. Engineered to have the smallest footprint, these switches also employ a modular design that enables the handle to be placed amongst the poles or at the ends. Amperage ratings of 30A to 1600A are available.
M-series Load Break switches are the most compact industrial grade switch on the market. Extremely compact and robust, these switches have a variety of mounting options including DIN-rail,
base, or door mounting. Load break disconnect switches are UL508 rated for branch circuit protection and are capable of making or breaking loads up to 600V. Load break disconnect switches are available in 20A to 80A models. A wide assortment of handles, shafts, and accessories increase versatility to accommodate any installation requirement.
FactoryMation is a nationwide top supplier of many quality industrial control products including Enclosures, AC Drives, Motors and Motor Controls, Relays, Sensors, and more. With an expansive distribution hub that houses over 40,000 products along with affiliates located nationwide, FactoryMation offers prompt shipment of a vast selection of products. FactoryMation offers many value added services to assist consumers in the tasks associated with the industrial controls industry and are backed by a knowledgeable support staff for all customer service and application needs.
FactoryMation
www.factorymation.com
Filed Under: TECHNOLOGIES + PRODUCTS, ALL INDUSTRIES, Factory automation, Switches
