Fan Reversal Module
By Mike Santora | August 24, 2015
OEM-Controls-fan-reversal-imageOEM Controls announces the Fan Reversal Module.
The fan reversal module is designed to keep the electric cooling fans clear of debris by periodically reversing the direction of the fan for a short time period. Because of this, it lets the product have a greater lifespan and also lets the end user continue with their application without any delays.
In addition, it uses the latest low on-resistance metal-oxide-semiconductor-field-effect-transistor (MOSFET) to control large electric fans drawing up to 30 amps while generating very little heat.
The fan reversal module can also withstand immersion in water because the PCB is fully encapsulated in a silicone potting material. Moreover, the internal microcontroller has ability to be programmed to meet the customers timing requirements, giving users full control at their fingertips.
OEM Controls
www.oemcontrols.com
Mobile Hydraulic Tips
Filed Under: Hydraulic equipment + components, Microprocessors
Tagged With: oemcontrols
Examining direct drive hydraulic maintenance
cylinder
Small, compact cylinder boasts large preload capacity
High modulus plastics for off-highway
Peninsular-Cylinder-top-10-coolest-things
Custom Peninsular Cylinder design named a finalist for “Coolest Thing Made in Michigan”
