FAQ: Why do some encoders have embedded microprocessors for signal processing?
By Lisa Eitel | June 19, 2016
Edited by Zak Khan || Embedded microprocessors in encoders offer many advantages. They improve reliability, accuracy and responsiveness. Plus in the case of magnetic encoders, embedded microprocessors can give encoders characteristics associated with optical encoders, but without optical-encoder drawbacks of sensitivity to dust.
Signal processing software running on a microprocessor can make rotation measurements that are accurate and dynamic, but with fewer moving parts than legacy encoder setups. Plus encoder microprocessors allow changes to measurement characteristics via software. That means users can tailor the encoder resolution, zero-point location and direction settings without mechanical adjustments.
Embedded microprocessors make encoders work as diagnostic tools and programming, too. This can reduce the time it takes to get integrated designs to market — plus reduce machine downtime once the design is up and running.
Microprocessors on encoders also enable different approaches to system design and configuration. Rather than wiring everything to one computer, embedded encoder smarts allow system configuration via smartphones or web portals.
Embedded microprocessors can also simplify the controller and drive system. Here, the embedded microprocessor performs various feedback and control operations; this can free up the drive system for other tasks.
encoder-FAQ07-feedback-incremental-microprocessors-0
Electronics are ever more compact, so putting microprocessors into today’s encoders is easy.
Furthermore, as the Internet of Things becomes more more of a reality in industrial applications, encoder-embedded microprocessors can provide data to system and operations-level networks. Rather than sending data to only a drive environment, embedded encoder microprocessors can send data to many components in the system and can also be checked by any other component in the system. While this creates quite a large amount of data, the embedded microprocessor allows handling it and interpreting it without burdening the host computer or drive system. This takes the encoder from a single-use component to a part of an integrated system.
For more information on embedded microprocessors for encoders …
Top Encoder Trends for 2015: Smarter, more reliable designs
Motion Control Tips
Filed Under: Motion Control Tips, Encoders • optical
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Encoders from SIKO support Industrial Ethernet
Draw-wire encoders from SIKO measure position, speed and inclination
Incremental encoders configurable via NFC (near-field communication)
Low-cost motion control offered with CLICK PLUS PLCs from AutomationDirect
