Fast cure adhesives now available for cartridge dispensing
By Patrick Curran | February 4, 2015
Epoxies Etc. has added three new fast-cure epoxies to the range of adhesive products suitable for use with TriggerBond® dispensing guns.
The TriggerBond system packages an adhesive’s two components into their own cartridges, which fit in a dual-barrel dispensing gun. Because the cartridges contain precise quantities of hardener and resin, TriggerBond produces the correct mix ratio every time you squeeze the trigger.
Epoxies-Etc-three-new-fast-cure-epoxies
The three new TriggerBond epoxies are each formulated for a different setting time:
  • 10–3005 sets in 5 minutes.
  • 10–3020 sets in 20 minutes.
  • 10–3046 sets in 46 minutes.
With shear strength up to 1,500 psi and notched Izod impact of 2.7 ft-lb/in, all three epoxies offer high-bond and impact strengths for structural bonding performance.
All three epoxies cure at room temperature and work with a wide variety of metal, ceramic and polymer substrates in electronics, industrial and jewelry applications. They’re available in black or clear as well as in different consistencies—such as high viscosity and non-sag.
Evaluation samples for industrial applications are available at: http://www.epoxies.com/try-adhesives.aspx
Epoxies Etc.
www.epoxies.com
Filed Under: Adhesives • epoxies
Tagged With: epoxiesetc
