Enfield’s high bandwidth pneumatic pressure control systems enable and enhance designs and concepts that are otherwise unattainable with slower electronic pressure regulators. With valve response times of less than three milliseconds, near instantaneous pressurization and depressurization of a reservoir can be accomplished.
In the above video, an example setup using an LS-V15s proportional pneumatic valve and C1 controller rapidly and accurately adjusts pressure from 0 to 100 psi (0 to 7 bar). The command signal, generated by the ASG-1 potentiometer, is closely tracked by the pressure in the chamber, as shown on the gauge.
Enfield Technologies
Filed Under: Valves, Pneumatic Tips
