Temposonics® linear-position sensors now have a faster update rate option, taking measurements every 100 µs for such applications as injection molding machines, extruders and thermoforming machines. The fast update rate option, available for SSI and EtherCAT® protocols, enables controllers to read the absolute position values with an update frequency of up to 10 kHz (independent of measuring length) synchronized with an external control clock to provide 26-bit absolute position data every 100 µs. In plastics applications, the sensors also generate up to 20 simultaneous position outputs along a given sensing element.
Typically there are four critical parameters for measurement on an injection molding machine; the clamping unit, the ejection unit, the injector itself and the tie bar. You can measure all four parameters with just two sensors rather than four.
MTS Systems Corp.
www.mtssensors.com
Filed Under: Linear motion • slides, Sensors (proximity), Test + measurement • test equipment
