Minneapolis, MN–FasTest's MIT-TM TwistMate® connector is specifically designed for connecting to the recessed 1/4″ NPTF transmitter manifold port (IEC 61518 2.126 (54) as well as 1/4″ side manifold ports. The unique “twist to connect” action provides a leak tight connection using no thread sealants or wrench tightening for vacuum or pressure testing to 2500 psi. These features eliminate wear and thread damage from repeated connections. The connector’s internal swivel also allows easy installation while plumbed (connected) to a supply line.
The standard MIT Series TwistMate connectors connect to side manifold ports with a few quick twists of the wrist to easily seal NPT female threaded ports up to 5000 psi while retaining high flow capacity. Sizes range from 1/8″ to 1/2″ NPT with additional sizes available upon request.
FasTest’s patented pressure assisted assisted grip and seal method provides a leak tight connection, resulting in the highest level of accuracy in the fastest time possible. The ergonomically designed connection tools improve productivity, product quality and user comfort resulting in improved calibration process and quality at reduced costs.
www.fastestinc.com
Filed Under: Fastening + joining, Connectors (electrical) • crimp technologies
