Minneapolis, MN–FasTest's MET-PT Series TwistMate® connector is designed specifically to connect and seal threaded pipe. The ends of steel pipe are often sharp from the cutting and threading process, and this abrasive surface can cause premature seal failure. FasTest engineers have addressed this problem with the TwistMate MET-PT Series connector, featuring a unique seal design that provides a durable sealing surface to ensure a leak-tight seal, every time.
No wrenches or tape are needed to make leak-tight connections in pressure testing applications. The patented TwistMate design provides a quick and user-friendly seal with a simple twist of the hand motion until surface contact is made. A leak-tight seal up to 750 psi is developed as pressure is applied.
For additional FasTest products or information, contact:
1-800-444-2373 • www.fastestinc.com • [email protected]
Filed Under: FASTENING • JOINING • locks • latches • pins, Connectors (electrical) • crimp technologies
