FCI, a supplier of connectors and interconnect systems, is proud to introduce the new NQ SMT Wire-to-Board Spring Clamp system as an extension of its Terminal Blocks portfolio.
The NQ SMT Spring Clamp includes a robust design, versatile modular system, secure electrical contacts, low wire insertion and high wire retention forces. Its user-friendly lever latch is engineered for effortless wire removal, while its compact industry-standard PCB design makes it a noteworthy space-saver.
With a low profile 5.00mm height, the NQ SMT Spring Clamp is highly ideal for LED devices and other compact applications, such as LED lighting modules. It is also suitable for consumer electronics, factory automation equipment, and applications which require easy-to-use wire insertion and extraction methods. Two contact pitch sizes are available, 2.5mm with a current rating of 5A (150V), and 4.0mm with a current rating of 7A (300V). Both models are end-to-end stackable and feature 1 to 10 contact positions.
“The NQ series marks another significant step forward for FCI in the LED lighting application segment, especially where compact and cost-effective solutions are required in the market. In addition, our extensive manufacturing and distribution footprint also ensures the NQ SMT Spring Clamp is conveniently and widely available at a global level,” adds Fabrizio Stango, Director for Commercial Portfolio at FCI.
FCI
www.fci.com
The post FCI Augments Terminal Block Solutions appeared first on Connector Tips.
Filed Under: Connector Tips, Terminal blocks
