    • Subscribe!
FDA/USDA/3A-Dairy compliant ETX scraper seals from LM76 for linear bearings used in food processing applications
By Lisa Eitel | May 19, 2017
LM76 now sells FDA/USDA/3-A Dairy compliant ETX Scraper Seals for linear bearings. Machined from Ertalyte PET-P, ETX Scraper Seals have high strength, excellent wear resistance, low coefficient of friction, and excellent dimensional stability at higher temperatures than seals from other materials. Designed with a slight interference fit between bearing ID and shaft, ETX Scraper Seals prevents contaminates and debris from migrating beneath the seal as it scrapes the shaft surface.
Ertalyte PET-P’s low frictional characteristics have little impact on drive force. These FDA/USDA/3-A Dairy compliant scraper seals are suitable for: Pharmaceutical, medical, food, and dairy processing applications.
EXT Scraper Seals feature a high continuous service temperatures up to 210°F (100°C) and offer good chemical and abrasion resistance, low moisture absorption, and resistance to staining. These linear bearing scraper seals keep bearings free from debris and bacterial contamination, are not affected by biological fluids, mild acids, can be washed down with cleaning agents, and steam cleaned. Snap-in EXT Scraper Seals are available for closed linear bearings, and closed pillow and flange blocks.
LM76 also manufactures a broad variety of FDA & USDA compliant bearings and shafting, in inch sizes of.25 inches to 1.5 inches, and a FDA & USDA compliant profile rail and slide system that can easily be integrated into new and existing applications. The bearing options include: Self-lubricating FDA & USDA compliant Teflon composite bearings in a 304-stainless steel shell, and lower cost bearings with a ceramic coated shell and FDA & USDA compliant liner. Bearings are available in closed and open configurations, and are drop-in replacements for all inch sized linear ball bearings.
Filed Under: Bearings
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Spacecraft, Vacuum Condition
Bearing life and effects of harsh operational environments
Figure4
How to make a gear-bearing from advanced polymer components
igus presents solutions to support mobility trends
bearing covers
Stock polymer and steel wheel covers for radial ball bearings
    • Subscribe!
