ARLINGTON, TX – Need to successfully regulate the rate of material flow from a hopper or bin? Martin provides a variety of solutions to increase the efficiency of your application. Consult with Martin to choose from uniform diameter screws, tapering diameter screws, variable diameter or variable pitch screws, cone screw feeders, live bottom bins, etc.
For fine free flowing materials uniform diameter screws are offered, or for material with lumps and dead space in flow, tapering diameter or variable pitch screws can be used. If a material tends to pack or bridge under pressure, bins with live bottoms and multiple screw feeders could be the answer. Components such as shrouded, or curved, cover plates are also available.
Martin Sprocket & Gear Company
www.martinsprocket.com
Filed Under: Screws • nuts • bolts, FASTENING • JOINING • locks • latches • pins, Material handling • converting, MECHANICAL POWER TRANSMISSION, Motion control • motor controls
