FerroQ ferrous wear analyzer
By Heather Hall | July 22, 2021
Poseidon System’s FerroQ is a standalone device that analyzes a small sample of oil for ferrous debris. The rapid and simple operation accompanied by outstanding sensitivity makes the device a perfect complement to any laboratory oil analysis. The device can be used as a low-cost screening tool to identify samples requiring further analysis, or as a standalone wear debris monitoring solution. The wide range and support for Grease Thief vials enables more flexibility and better measurements and more flexible operations.
Features
  • Accurate results in seconds
  • Bluetooth and USB connectivity for automation
  • Touchscreen display
  • Small sample needed
  • Calibration independent of base fluid used
  • Support for multiple sized vials
Applications
  • Oil analysis labs
  • Wind energy
  • Oil and gas processing
  • Oil refineries
  • Power generation
  • Gas compression
  • Manufacturing
  • Pulp and paper
  • Transportation
  • Aerospace
  • Process machinery
  • Military
Poseidon Systems
www.poseidonsys.com
You may also like:
  • How to design an effective telehealth system
  • MB dynamics
    Test bench supports brake hydraulic pressure, electric parking brake R&D
  • Connectivity building blocks for motion control
  • KACO expands portfolio of shaft grounding rings
  • Solar Atmospheres receives Nadcap 24-month merit status
  • Vesconite’s new Hitemp 160 gets food-contact certification
Filed Under: Safety systems + components, Test + measurement • test equipment
Tagged With: Poseidon, Poseidon Systems, poseidonsystems
mti
MTI
moog
