Festo CPX-AP-I next-generation remote I/O for pneumatic installations
By Lisa Eitel | October 17, 2019
The new Festo remote I/O system CPX-AP-I, which improves the performance of mixed valve terminals and I/O systems, is compatible with most communication protocols — including EtherNet/IP, PROFINET, and EtherCAT. These rugged, compact, and lightweight modules can be mounted directly on machines in IP65/IP67 rated environments. CPX-AP-I recently received a 2019 Reddot award for product design.
This remote I/O improves the performance of mixed valve terminals.
CPX-AP-I enables valve terminals to be moved closer to pneumatic cylinders, which reduces pressurization time and increases the machine’s overall performance. Process data in and out of each bus module is as much as two kilobytes. Scan cycles for a mix of both valve terminals and I/O are below one millisecond and are expected to approach microseconds. Latency is virtually nonexistent.
Another important feature is that communication and voltage supply are via two separate connecting cables that are also galvanically isolated, eliminating the potential for stray currents. Two separate wires enable the creation of voltage zones that provide reliable control for a host of machine processes.
CPX-AP-I comes standard with a pre-integrated IO-Link Master and IO-Link device tool for fast, effective application of IO-Link enabled devices. CPX-AP-I ensures that each application can be individually optimized. Cross-communication between modules enables applications needing high speed and rapid control.
CPX-AP-I remote I/O has the capacity of up to 80 I/O modules, which can be a mix of digital I/O, analog I/O, I/O-Link, and valve terminals. Furthermore, the distances between modules is up to 49 feet (15 meters). CPX-AP-I has a theoretical upper limit of 500 I/O modules and 164 feet (50 meters) distance between modules.
“CPX-AP-I builds on the best features of the remote I/O technology available today and then goes farther by incorporating the latest Ethernet ASIC technology and productivity tools,” said Sandro Quintero, Product Manager of Electric Automation at Festo. “CPX-AP-I offers the best price and performance ratio of any system combining decentralized I/O with valve terminals.”
For more information on the CPX-AP-I, visit www.festo.us.
You may also like:
  • Festo Didactic's Thomas Lichtenberger
    Talking manufacturing and education with Festo Didactic’s Thomas Lichtenberger
  • How to better integrate IoT devices — use Apps
  • Pick-and-place applications with Festo tools — showing at Pack Expo
  • Mitsubishi Electric introduces new remote I/O modules
  • hummingdr1
    Robo Firefly drone goes small for efficiency, waits on crowdfunding
Filed Under: I/O modules, Valves
Tagged With: festo
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Beckhoff I/O terminal supports high-voltage measurement for renewable energy and EV technologies
Opto 22 releases groov RIO EMU distributed energy monitoring unit
Opto 22 releases new groov EPIC I/O modules for large-scale power monitoring, signal integration
lutze
Overload current-control module features super-thin form factor
