Easily clamp materials in a variety of shapes and sizes with Festool’s new lever clamp kit.
Festool, a manufacturer of precision-engineered power tools, released its new Quick Clamp — a durable multi-function table (MFT) lever clamp that holds workpieces in place, offering an easy fasten-and-release functionality.
The company also launched a limited-edition Plier Systainer Set for remodelers, carpenters, and electricians looking to bolster their shop selection
“The MFT Lever Clamp was initially introduced as part of a limited edition set earlier this year and, thanks to customer demand, we’re proud to now offer the Lever Clamp as a standalone permanent item in our portfolio,” said Rick Bush, product marketing manager at Festool. “In addition, the Pliers Systainer Set includes seven limited-edition tools that feature excellent fit and finish.”
The Lever Clamp MFT-HZ 80. Festool’s Quick Clamp lever makes clamping a smooth process. For the first time, it’s available as a permanent, standalone product. The robust, long-lasting tool can be transported from project to project for years to come.
The clamp works on a variety of materials up to a height of 3-1/8″ (80mm) and the lever makes it quick and convenient to clamp and release workpieces one-handed without slipping. It is compatible with the MFT hole pattern, making it easy to attach to a MFT or a mobile workshop.
Pliers Systainer Set. Neatly organized in the latest generation of Systainer storage featuring a unique blue color for quick and easy identification, Festool’s seven-piece limited edition Pliers Systainer Set offers solutions for several applications. The pliers are extremely sturdy and built for a range of projects involving holding, gripping, bending, and cutting. The set includes one of each of the following: adjustable plier, linesman plier, extended reach plier, end nipper plier, diagonal cutter plier, bent needle nose plier, and wire stripper plier.
The pliers feature advanced cutting strength, clean finishes, and comfortable handles. Several feature a slot to attach a lanyard for added security when working from higher elevations. The German-made, seven-part set expands application possibilities to wires, connectors, nuts, nails, and common electrical and remodeling tasks. The set components are stored in the professional EPP foam tool inlay in a Systainer so they are ready to go for any project.
Filed Under: Clamps • locks • latches, Tools for fastening
