Fiber Reinforced Epoxy Adhesive
By Patrick Curran | January 28, 2010
Hackensack, NJ – Comprised of an aramid fiber reinforced epoxy adhesive for high performance structural bonding, Master Bond’s EP30R features outstanding dimensional stability and enhanced impact resistance. This two part epoxy is formulated to cure at room temperature or more rapidly at elevated temperatures. Master Bond EP30R produces high strength bonds to metals, glass, ceramics, vulcanized rubbers and many plastics. The structural adhesive is recommended for use over the temperature range of -60°F to more than 250°F and it resists thermal cycling and chemicals.. Cure shrinkage of only 0.0003 inches/in preserves precise dimensional tolerances of assembled parts. Severe mechanical or thermal stresses do not weaken adhesive performance. The cured epoxy is an excellent electrical insulator.
Master Bond’s EP30R is a high viscosity, easy to apply compound. It spreads evenly and smoothly and only contact pressure is required for cure. 100% reactive, this epoxy adhesive contains no solvents or other volatiles. Unlike many epoxy reinforced systems, it has superb impact strength values combined with rigidity properties. Master Bond EP30R is recommended for applications where adhesive strength, dimensional stability and impact resistance must be maintained even upon prolonged exposure to adverse environmental conditions.
Master Bond
www.masterbond.com/prodtype.html
Filed Under: Adhesives • epoxies, Materials • advanced
EXE014 - Image 1
