Kits facilitate adjustable-depth enclosure rails
By Lee Teschler | September 16, 2021
Corner Adjustable Depth Kits (CBS ARCA) are new accessories for the ARCA – IEC series enclosures that allow users to prepopulate the back panel or DIN-Rail mountings outside the enclosure and quickly slide the assembly into the cabinet when fiboxready. Once the hardwired connections are secured, the project is ready for the field. The CBS is available in all three enclosure depths ( 150 mm, 210 mm, and 300 mm).
Placing components at various depths permits greater flexibility in configuring designs and enhanced airflow circulation.
The ARCA – IEC cabinet enclosure is the first real enclosing alternative to steel. Sized up to 32x24x12 in, this watertight impact and UV-resistant polycarbonate enclosure will not dent, rust, crack or bloom like steel or fiberglass and weighs less and is much easier to modify and transport.
Fibox, 810 Cromwell Park Drive Suite R, Glen Burnie, MD 21061, [email protected], www.fiboxusa.com
You may also like:
  • scilab
    The top ten free engineering math software packages
  • don't worry about EV fires
    Don’t worry about EV fires
  • electrocaloric cooling
    Keeping cool with capacitors
  • pie in the sky
    Sizing up renewable energy aspirations
  • condo collapse
    Simulation brings insight into the condo collapse
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
Tagged With: fibox
50 years of bit parallel encoders from POSITAL
EXAIR 3D model and CAD Library has more than 70 extensions
New igus E4.1R rol e-chain reduces noise, vibration and saves electricity
