    • Subscribe!
Filter out chips with EXAIR’s Chip Trapper
By Kelsey Zebrowski | March 23, 2020
EXAIR’s patented Chip Trapper offers a fast, easy way to clean chips, swarf and shavings out of used coolants and other liquids. The Chip Trapper vacuums the coolant or liquid that is filled with debris and traps all the solids in a reusable filter bag. Only the liquid pumps back out. It is ideal for use on machines with sumps, parts washers, tanks and storage containers of contaminated liquids.
A sudden lack of coolant flow in a machining operation will likely damage the part and expensive tooling. Machine tools commonly discharge some chips and shavings into the coolant sump. As the chips accumulate and mound up, this can result in downtime to fix the problem.Exair chip trapperThe Chip Trapper uses EXAIR’s compressed air powered Reversible Drum Vac (included) that can fill or empty a 55 gallon drum in less than two minutes. Simply set the Reversible Drum Vac pump and directional flow control valve on top of the drum to “fill” for it to quickly vacuum the liquid with solids. Once the sump, pit or tank is empty, set the pump and directional valve to “empty” for it to pump out clean coolant/liquid. All the chips and other solids are trapped inside the reusable filter bag of the Chip Trapper. The stainless steel pump has no motors or impellers to clog or wear out and there is no electricity or shock hazard! EXAIR is offering a special right now on all Industrial Vacuums. Learn more at exair.com/58/vacpromo
For more information, visit exair.com
You may also like:
  • Exair no drop atomizing nozzles
    No-drip air atomizing nozzles conserve precious liquids
  • EXAIR’s single point ionizer for spot neutralization
  • EXAIR 303SS air conveyor converts standard pipe to convey in…
  • EXAIR Gen4 Ion Air Jet eliminates static and dust
  • EXAIR now offers selectable voltage power supply for static eliminators
Filed Under: Pumps
Tagged With: exair
ironhorse-AD-jet-pump-image
IronHorse jet pump and stainless steel motors from AutomationDirect
KNF’s Diaphragm Liquid Pump FP 70 provides a smooth flow and high efficiency solution
KNF’s new smooth flow, high efficiency diaphragm liquid pump FP 70
spartan scientific high-pressure solenoid pump
High-pressure solenoid pump offers fluid control for rigorous needs
    • Subscribe!
