Fischer FiberOptic connector performs in extreme environments
By Editor | December 6, 2012
Fischer Connectors releases its new push-pull FiberOptic interconnecting solution specially designed for premium optical performance in extreme environments. Fischer monitors the fiber optic trends closely and adapts its connectors to the users’ needs. The Fischer FiberOptic interconnecting technology offers the essential quality and stability needed for an optical link combined with extreme robustness, easy mating and easy cleaning.
The Fischer FiberOptic with two (FO2) or four (FO4) optical channels features some major revolutionary novelties. Fischer Connectors offers a fiber solution that is extremely quick and easy to clean thanks to a removable mono-block mate adapter and to the possibility of rinsing the unmated connectors freely under water or in an ultrasound bath.
The Fischer FiberOptic connector will perform perfectly in harsh and extreme environments. It has a high ingress protection of IP68 (2m/24hours) when mated and IP67 in unmated conditions. In addition, Fischer Connectors’ FiberOptic optical performance is insensitive to mechanical strain on the connector. The spring optical contacts employed allow for filtering out any stress applied to the connector housings while keeping the typical advantage of a push-pull solution: quick, safe and easy locking.
Fischer-Fiberoptic
The Fischer FiberOptic connector can be used in a wide range of fields requiring faultless quality in outdoor or demanding applications, such as Transport & Mobility, Telecom, Energy, Defense & Security, Broadcast, Construction & Infrastructure and Medical Devices.
Key specifications:
  • IP68 2meters/24hours Mated & IP67 (1meter/30min) Unmated Ingress Protection
  • Extreme Environment FiberOptic Solution (Norm IEC 61753-1 Cat. E)
  • Multi-channel (2 & 4), SM & MM Optical Fibers, UPC & APC Polishing
  • Push-pull Mating Plugs & Receptacles
  • Optional Gas Tight Panel Receptacles (IP68 or <10-6 mbar l/s)
  • Removable Mono-block mate adapter
Fischer Connectors
www.fischer-fiberoptic.com
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical
Tagged With: fischerconnectors
molex-premo-flex
