    • On the Floor
Fix a loose screw easily with Tank Bond Thread-Stopper Tape
By Michelle Froese | April 20, 2021
Fixing a loose screw has never been easier or faster than with the new Tank Bond Thread-Stopper Tape from DAP, a supplier of solutions for home improvement and construction projects.
Simply wrap the tape around the threads of any loose screw for a fast and effective solution. Screws treated with Thread-Stopper Tape can still be easily removed and reused up to three times.
The Thread-Stopper Tape is the newest addition to the Tank Bond collection, a complete line of hard-working formulas ideal for an extensive list of professional and DIY applications.
“Our new Tank Bond Thread-Stopper Tape is designed to fix loose screws faster and easier than ever before,” said Chuck von Nordeck, product manager at DAP. “Like our entire family of heavy-duty Tank Bond formulas, this tape offers durable, reliable repairs that will last.”
The Thread-stopper Tape absorbs shock and vibration while holding screws tightly in place. It works on all fastener types and sizes and is ready immediately — meaning no dry time is required. Simply wrap the tape around the threads of any loose screw for a fast and effective solution.
Screws treated with Thread-Stopper Tape can still be easily removed and reused up to three times. The tape works on metal, wood and plastic, and a single roll covers up to 150 screws so you can fix every shake, slip and rattle on the job or around the home.
Combined, the Tank Bond family of adhesive products are strong enough to tackle repairs ranging from tools, household items and outdoor maintenance to boats, bicycles, automotive, motorcycles and even musical instruments.
The complete collection also includes:
Tank Bond Thread Stopper — provides an adjustable, reusable solution. Users can now turn any size and type of screw or bolt into a self-stopping, shock-absorbing fastener by applying Tank Bond Thread Stopper. Simply apply to the fastener, let dry and then install.
The non-locking formula creates a strong hold without permanently bonding threads, allowing fasteners to be easily removed and replaced with manual tools up to five times. The product coats the threaded bolt or screw with a gel-like coating to help absorb shock and vibration. Thread Stopper is a multi-material solution that can be used on metal, wood, plastic and more, and won’t damage or crack plastic like a traditional threadlocker.
Tank Bond Liquid Grip — prevents stripped screws for easier installation or removal. Some screws just do not want to install or be removed. When your bit first slips, it’s common to respond by adding more force, but this only increases the potential for the screw to strip.
Adding just a drop of Liquid Grip to the screw head provides up to seven times more grip, giving it the extra bit of surface traction needed to easily install or remove, while preventing unnecessary wear and tear on your tools. The Liquid Grip formula works on all fastener types and sizes, and cleans up easily from tools and fasteners when work is done – simply wipe with a paper towel.
Tank Bond Heavy Duty Advanced Epoxy — handles the toughest repairs. An aggressive adhesive, DAP Tank Bond Heavy Duty Advanced Epoxy delivers military-grade adhesive technology, offering superior bond strength and impact resistance.
Formulated to be four times tougher than typical epoxies, it’s the ideal solution for repairing items that undergo heavy force or vibrations, such as lawn mowers, bikes, exercise equipment and power tools — and it can be used on minor automotive repairs, such as for fixing cracked bumpers.
While substrates bonded with brittle epoxies often fail under these conditions, Tank Bond retains its hold even when substrates are bent or warped by force. Beyond its strength, it also offers an easy-to-use application that requires zero surface preparation and cures in as fast as 30 minutes on most substrates, enabling users to tackle tough repairs quickly. Tank Bond works on metal, plastic, tile, ceramic, glass, stone, wood, and is particularly suited for metal bonding.
Tank Bond Clear Epoxy — provides a fast and clean repair. Demanding repairs don’t need to be accompanied by unsightly results when you have the right product on hand. Formulated to deliver a stronger-than-super glue bond, DAP Tank Bond Clear Epoxy delivers a high-strength, durable repair that dries clear for a clean-looking repair that will blend smoothly with the original substrate.
The multi-material adhesive provides a strong, clear bond on metal, plastic, tile, ceramic, glass, stone and wood for a super-versatile repair solution. Tank Bond Clear Epoxy also offers gap-filling capabilities and forms a water-resistant bond perfect for interior and exterior repairs. Plus, the fast-setting formula reaches handling strength in as fast as five minutes so you can be sure the repair has set up right and will cure properly.
Tank Bond Gel Threadlockers — repeated vibrations and frequent usage can cause even tightly secured screws to come loose over time. DAP Tank Bond Gel Threadlockers offer the strength needed to withstand constant force and avoid the mess of typical drippy threadlockers thanks to a gel-like formula that won’t drip or run, and is ideal for vertical applications.
Available in two formulas, Removable and Permanent, these easy-to-use threadlockers ensure screws stay securely in place with reinforced strength. The product will fix rapidly in 10 minutes, and is fully cured within 24 hours for a strong, secure bond. Any excess adhesive is easily wiped away with a paper towel.
Filed Under: Adhesives • epoxies
Tagged With: dap
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
