Five-axis modular system combines clamping and locating
By Lee Teschler | September 30, 2021
A Modular Pull Clamping System allows for 5-axis machining without tool interference. This system can also be used as a mechanical zero point clamping system for quick fixture change with 0.005-mm accuracy.
While conventional fixtures may restrict machining on certain faces of the workpiece, the modular pull clamping system allows clear access for machining from modular clampfive sides, eliminating the need for additional setup to machine the other sides. Compact in size and completely modular, this versatile and simple clamping system allows easy height adjustment by stacking the modules. The pins or screws can be easily attached to the underside of a plate or a workpiece for a standardized locating.
The modular clamp bodies are offered in flanged, double, and single types for a variety of mounting configurations. Together with the bushings, tapered pins and clamping screws, this system is designed to save space and increase efficiency in a variety of clamping applications. For vertical applications, the modular hook-type clamping system enables you to support the workpiece quickly and safely before clamping.
Fixtureworks, 33792 Doreka Dr., Fraser, MI 48026, 586-294-1188, www.fixtureworks.net
You may also like:
  • scilab
    The top ten free engineering math software packages
  • don't worry about EV fires
    Don’t worry about EV fires
  • electrocaloric cooling
    Keeping cool with capacitors
  • pie in the sky
    Sizing up renewable energy aspirations
  • condo collapse
    Simulation brings insight into the condo collapse
Filed Under: TECHNOLOGIES + PRODUCTS, Automation components
Tagged With: imaofixtureworks
EXAIR.com Improves Web Accessibility with ADA Compliance Features
Custom air knives from EXAIR for unique applications
Aerotech introduces two-axis laser scan head
SureFrame cut-to-length T-slotted rails
