    • Subscribe!
One-touch indexing clamps combine easy clamping with precision locating
By Lee Teschler | October 12, 2021
A new lineup of One Touch Indexing Clamps features easy fastening and precision locating in a single operation where components slide or rotate into position. The tapered contact surfaces provide ±0.05 mm repeatability.
The quarter-turn knobs allow for quick locking and unlocking without the use of tools. The ON/OFF markings and perceptible “click” indicate the locked and fixtureworksunlocked states. Red indicator band is visible when fastener is in the OFF (unclamped) position.
The three-position versions feature coil spring pressure and includes a “MID” position on knob between the ON and OFF positions, allowing the plunger to snap into a hole when it slides into position. The spiral cam mechanism provides for high clamping forces (40 lb) and a high allowable axial load (300 lb).
The plungers can be used with precision tapered bushings for locating or a simple through-hole in a plate. The One Touch Indexing Clamps are available in flanged style to mount from the underside with three screws or a threaded style to mount in a tapped hole.
IMAO Fixtureworks, 33792 Doreka Dr, Fraser, MI 48026, (586) 294-1188, www.fixtureworks.com.
You may also like:
  • 9-11 truthers
    The WTC collapse after two decades
  • scilab
    The top ten free engineering math software packages
  • electrocaloric cooling
    Keeping cool with capacitors
  • pie in the sky
    Sizing up renewable energy aspirations
  • condo collapse
    Simulation brings insight into the condo collapse
  • how to think
    STEM classes don’t teach engineers how to think
Filed Under: TECHNOLOGIES + PRODUCTS, Automation components
Tagged With: imaofixtureworks
robotics-smart-farming-faulhaber-products
Faulhaber: The smart future of agriculture
EXAIR.com Improves Web Accessibility with ADA Compliance Features
Custom air knives from EXAIR for unique applications
Aerotech introduces two-axis laser scan head
    • Subscribe!
