Flat/High Latchable Rail Enclosures Capable Of Performing Multiple Functions
By OKW Enclosures Inc | August 8, 2017
OKW has unveiled new flat/high RAILTEC B DIN rail enclosures that accommodate connections at different levels and offer extra space.
RAILTEC B is a universal DIN rail enclosure that meets machine-building and motor industry regulations. It can be mounted on TH35 DIN rails or directly on walls for applications including control equipment, notably lighting systems.
Various versions are available – with or without ventilation – for PCB terminal blocks; plug headers; front connectors (closed case) and D-SUB connectors. Open case enclosures enable the fitting of different combinations of terminal guards.
The new flat/high variant is available in two, four, six and nine modules (pitches 5.0/5.08 mm) – offering sizes from 1.38” x 3.39” x 2.28” to 6.18” x 3.39” x 2.32”.
RAILTEC B is fully insulated and protected to VBG 4. It is molded from light gray (RAL 7035) polycarbonate (PC, UL 94 V-0) as standard. Prices start at $7.
Accessories include a bus system for enclosures that share common power and data connections; wall suspension elements; terminal blocks; plug headers; self tapping screws (0.098” x 0.236” PZ1) and transparent lids.
OKW can supply RAILTEC B fully customized ready for PCBs. Services include EMI/RFI shielding; CNC machining; lacquering; screen, tampo and digital printing of parts and labels; membrane keypads; display windows; plastic and aluminum panels; installation and assembly of accessories.
Filed Under: M2M (machine to machine), Terminal blocks
