Flex M Couplings for Flatbed Laser Cutters and Engravers
By Sponsored content | September 1, 2022
A UK manufacturer of industrial grade flatbed laser cutters and engravers required precision couplings for use on their line of laser systems. The company’s machines are globally renowned for their accuracy in all levels of industry, from small architect model makers and education establishments, through large automotive plants.
CadCam’s certified Class 1 machines use sealed CO2 lasers that are water or air cooled. A fine, accurate depth of cut is achieved by software controlled adjustment of both the cutting speed and the power output of the laser. Closed-loop servo motors and hardened steel rails provide precision movements with up to 2G acceleration.
Huco Dynatork Flex M (membrane type) precision couplings were selected to help tolerate and compensate for any slight misalignment in the machines X-axis half drive shafts. “The Huco coupling enables the accuracy of the X-axis to be maintained by its action on the drive shaft.” explains Richard Extall, purchasing manager at CadCam Technology. “This is imperative to maintain the accuracy of our machines, which is to within 0.025 mm.”
Huco’s Flex M precision couplings feature thin pressed steel membranes – torque is resolved to simple tensile stresses in opposing segments of the membranes. The couplings have near-infinite life and a dynamically balanced construction which makes them suitable for applications requiring high rotational speed and motion integrity. CadCam utilizes the double stage version of the Huco Flex M coupling – two membranes gives even greater misalignment capacity.
Learn More
About the author:
With more than 40 years of innovation, Huco is recognized as a world leader in precision coupling and piston air motor technologies. Backed by extensive application experience, utilizing the most advanced materials, Huco designs and manufactures innovative power transmission solutions that meet the most demanding customer requirements.
Sponsored content by Altra Motion
Filed Under: Altra Motion Sponsored Content
Tagged With: Altra Motion
