Fierce Flex Extreme Heat TC-ER STOOW MTW flexible cables from Northwire Inc., Osceola, Wis., are UL listed and CSA certified and can perform in extreme temperatures ranging from –40° to 105°C.
Featuring a small diameter and low durometer, the flexible cable is easy to install and terminate lowering assembly costs. With the exposed run rating, no conduit is required, saving installation time and money. Northwire’s Fierce Flex Extreme Heat TC-ER STOOW MTW custom cable offers superior torsional, rolling, variable, bend, radial and continuous flexibility from –25° to 105°C and an extreme cold bend temperature rating of –40°C. Options for shield, over-braid, foil, wraps and strength members in hybrid, composite and custom designs for 600-V signal, control, instrumentation and power distribution are available in a gauge range from 18 – 6 AWG.
Over-mold and assembly compatible, REACH and RoHS2 compliant, harmonized approval options include UL 1277 Tray Cable, UL 62 STOOW 105°C, CSA 49 STOOW 105°C, NMX-J-436-ANCE-2010 105°C, UL 1063 MTW and ANSI, IEEE, NEC Articles 336 and 400, NFPA 70 and 79. Approved for all colors, private labels and custom legends enable visual identification aiding wire and cable installers. Resistant to impact, crush, flame, oil, chemical and sunlight, this high flex cable is suitable for use in Class I, Div 2 areas and wet locations.
Engineered for mechanically and environmentally rugged industrial applications, Fierce Flex Extreme Heat cable is ideally suited for confined spaces and routing for interconnects due to its superior flexibility.
Northwire Inc.
www.northwire.com
The post Flexible custom cable for extreme temperatures appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
