Flexible shaft coupling for leadscrew assemblies
By Mike Santora | November 7, 2017
Helical-Flexible-for-Leadscrew-appThe Challenge
The customer wished to enhance their line of leadscrew assemblies by being able to offer a flexible coupling. This flexible coupling would allow the customer to present a more complete package with their product. They envisioned using our standard flexible coupling AC075 with a 10-32 threaded bore.
The Solution
As you can see, it developed into a final configuration of 1.00″ OD, 1.28″ long, integral clamps (10-32 thread in the A2 bore, wrench flats were placed on this end as well). Also, to blend the flexible coupling into their system they had asked that it have a black anodized finish. The development time was a mere three months from first contact to first order. This is the case that occurs many times – The customer wants a standard coupling except for . . . “threaded bore; O.D. change; wrench flats”. . . otherwise, it’s a standard coupling.
Helical
heli-cal.com
Filed Under: Coupling Tips
Tagged With: helical
Ringfeder — Dynamical torsional stiffness: some couplings need finer tuning
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
