The Sensor Connection a division of Harold G. Schaevitz Industries LLC, has expanded its line of temperature sensors with the addition of the CHT-FS series Cylinder Head Temperature (CHT) Sensor. Installed under the spark plug or head bolt for monitoring of engine performance and critical over-temperature conditions. The unique flexible stem design allows for installation in high-temperature areas with limited clearance.
Features:
- Type K Thermocouple
- Temperature Measuring Range: -40°C to +1000°C
- Available for 10, 12, 14, or 18 mm OD bolts/spark plugs
- Custom Flexible Stem lengths available
- Made in the USA
Typical Applications:
- Unmanned Aerial Vehicles (UAVs)
- Light Aircraft
- Power Generators
- Automotive Engine R&D
- Motorsports
thesensorconnection.com
Filed Under: Sensor Tips
