General Cable, Highland Heights, Ky., has launched TC-Flex industrial tray cables for use in industrial plants, factory automation, wind turbines, and appliance applications. They meet a full range of UL and CSA listings.
Featuring a rugged PVC/Nylon/PVC construction they are easy to install, resilient and durable.
TC-Flex tray cables are available in shielded and non-shielded copper constructions and can be installed without conduit or cable tray, in accordance with applicable NEC guidelines. Phase identification of TC-Flex Cable, consisting of black numbered conductors with a green/yellow grounding conductor, facilitates the ease of installation.
In addition to cost savings, TC-Flex tray cables are oil-, solvent-, and sunlight-resistant, and RoHS and REACH compliant. They can be cut-to-length per request.
General Cable
www.GeneralCable.com
The post Flexible tray cables available in shielded and non-shielded copper appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
