FlexTorq(TM) 762 Hollow Shaft Offset DC Gearmotors
By Design World Staff | January 22, 2009
St. Charles, IL – Designed to fit into high torque, tight space applications, and featuring either a 1.25″ (31.75 mm) I.D. hollow shaft or a 1.25″ diameter solid shaft in the u-shaped or s-shaped configuration, Bison Gear & Engineering Corp. introduces its new FlexTorq‚â„¢ 762 series hollow shaft offset DC gearmotors. Driven by 1/20, 1/4 or 1/2 HP (37, 186 or 373 Watt) permanent magnet 90 volt DC variable speed motors, the FlexTorq‚â„¢ 762 series is available in 9 standard off-the shelf models from Bison Gear and its distribution partners.
Fixed output speeds on the standard FlexTorq‚â„¢ units range from 1.2 to 65 RPM and Bison can provide matched variable speed drives for the PMDC gearmotors. As part of its Robusticity‚â„¢ design philosphy, Bison’s pinion gears are integral to the motor shaft. Carbide cutting tools are used to hob the pinion teeth on automated hobbers. The pinions are then heat treated in a carbonitriding process that offers a hardened, wear resistant surface. Bearing and gear life are maximized with oil bath lubrication, rather than grease.
The FlexTorq‚â„¢ gearmotors are manufactured in Bison Gear’s suburban Chicago facility to Bison’s high quality standards in order to ensure a short supply chain and reliable, long-life operation. In addition, Bison’s Innopreneurial‚â„¢ application and design engineering capabilities to customize standard models to meet specific OEM needs are readily available.
www.BisonGear.com
Filed Under: Motion control • motor controls, Motors (gearmotors)
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
