    • Subscribe!
Floyd Bell announces 115 dB AT 9-30Vdc voice-capable piezo alarm
By Andrew Zistler | December 14, 2015
img_announcerThe Announcer line of pre-programmed speakers provide endless possibilities for any announcement need such as voice messages, sound effects, loud sirens or other tones. The messages are stored within the device, so a simple application of power is all that is needed to provide alert information to the user. From the large AN450 to the piezo-alarm-sized AN125, the Announcer Series products expand your ability to relay important alarm information to end-users. Its possibilities are limited only by your imagination.
The New AN450 Announcer is a powerful and rugged industrial announcement system for playing pre-recorded voice and audio messages. The AN450 can play back up to 8 minutes of high output (up to 115dB) audio. The audio can be divided into 8 separate messages, selectable via input logic to the system. An internal potentiometer allows the user to adjust the sound output level. This large (5.5” round) programmable speaker is well-suited for situations in which high levels of ambient noise are present. It can be mounted via a stainless steel bracket (included) to allow a customizable mounting angle, but can also be panel-mounted or direct-mounted to a standard handy box via our special molded rear cover.
Looking to replace an existing piezo alarm with a voice message? AN100 and AN125 Announcer™ Series alarms from Floyd Bell play a pre-recorded audio message up to ten seconds at 95dB. The same size as a standard piezo alarm, these panel-mount speakers provide the ability to replace an ambiguous beep with voice instructions or warnings. If you’re looking for a panel-mount audio alert and a standard buzzer just doesn’t get the point across, consider using an AN100 or AN125 to replace a beep or siren with a clear voice!
Floyd Bell
floydbell.com
Filed Under: Flanges • supports • mounts • brackets, Safety systems + components
unnamed-30
SICK adds microScan3 Pro I/O safety laser scanner
Modular safety gate system from Pilz now includes the PSENmlock handle module
Automation24 adds Schmersal Machine Safety Devices to its online shop
DEM hazardous area and general purpose safety devices
    • Subscribe!
