Force Guided Relays from IDEC
By Patrick Curran | June 4, 2010
Sunnyvale, CA – Force guided relays are often used in safety circuits to detect failures such as contact welding and damage to the contact spring, This requires them to meet international standards such as EN50205. Exceeding these strict standards, new RF1V Force Guided Relays also offer faster response times ensuring your circuit is able to open quickly providing the safety you need.
IDEC-RF1V-Force-Guided-Relays
Improved anti-shock properties mean these relays can be used safely in high shock and vibration environments such as in machine tools and other factory equipment. Plus an optional built-in LED allows for quick and easy detection if power is applied to the relay. This makes RF1V ideal for use with production equipment for automobiles and semiconductors, as well elevator controls where the use of force guided relays is required by international safety standards.
IDEC Corporation
www.idec.com/usa
Filed Under: INDUSTRIAL SAFETY SYSTEMS, Relays, ELECTRONICS • ELECTRICAL
