HIWIN’s WE series features equal load ratings in the radial, reverse radial and the lateral direction with contact points at 45 degrees. This, along with the wide rail, allows the guide way to be rated for high loads, moments and rigidity.
By design, it has a self-aligning capability that can absorb most installation errors and can meet high accuracy standards. The ability to use a single rail and to have the low profile with a low center of gravity is ideal where space is limited and/or high moments are required.
Filed Under: LINEAR MOTION
