  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Frameless motor basics video: Operation, integration, and application
By Lisa Eitel | December 20, 2017
Frameless motors are rotor-and-stator subcomponent sets that aren’t prefixed in a traditional motor housing. They don’t include an output shaft (or shaft-support bearings) either. Instead, the OEM or design engineer works with the supplier to tightly integrate the frameless motor stator and rotor directly into the machine and framing. Watch this video for more:
However, the fundamental operation of frameless motors is just like that of conventional permanent-magnet and induction motors. Frameless motors are powered by drives … they are sold in frame sizes and according to the voltages for which their windings are intended; most leverage Hall sensors and encoder feedback for high resolution; and some are UL listed to simplify design verification for OEMs.
Note that some frameless motors take the form of brushless servomotors to drive precision axes as any other servomotor system. In contrast, other frameless motors function as torque motors. These direct-drive electric motors usually have large diameters and higher pole-counts and run at lower speeds than servo motors … which in turn means they deliver higher torque than servomotors.
One major advantage of frameless motors is extremely high stiffness. Of course, a design’s overall stiffness depends on that of all its components. Traditional designs include a motor with a shaft coupled to mechanical transmission components like belts and pulleys, lead screws, or gearboxes. Even shaft stiffness can have a significant effect on system stability — as it’s a function of diameter cubed.
Frameless torque motors offer don’t need the transmission components with their attendant lost motion and stability issues. The result is output-transmission stiffness that’s sometimes dozens of times more torsionally stiff than traditional motor outputs.
Design variations of frameless motors abound. Here we’ve focused on frameless motors that are shaftless — the most common variation implied with the term frameless.
The bore on these motors lets machine builders configure machines in a myriad of ways. But consider another variation is a housed torque motor that includes a bearing set, position feedback device and usually a temperature monitoring device. This concept requires less application engineering by the user but also limits design flexibility.
One caveat: Though frameless motors offer many advantages, they require more application-specific engineering, which means they are generally found only in higher quantity production products like CAT scanners or in low quantity builds where cost is not the primary consideration like a telescope. That said, the engineering investment in frameless-motor integration can impart competitive performance advantages.
In fact, customized winding designs on frameless motors can accommodate special voltage requirements; thin-lamination variations can boost efficiency in high-speed applications, and frame diameter size is basically unlimited. Class F winding ratings on some motors allow for temperatures to 155 °C. Likewise, rare-earth neodymium iron boron magnets are standard on many frameless-motor offerings … but some manufacturers offer motors with samarium-cobalt magnets to withstand very high-temperature environments.
About Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Tell Us What You Think! Cancel reply
MOTION DESIGN GUIDES
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High Strength, NASA Low Outgassing Approved Epoxy
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
