Fuji Machine: New IoT technologies for machining automation — See them at IMTS
By Lisa Eitel | August 23, 2018
Fuji Machine’s introduction of LAPSYS, Fuji’s concept of the Internet of Things (IoT), enables part traceability, predictive maintenance and remote operation for unprecedented machining automation and efficiency. Linkable to any Fuji machine, LAPSYS desktop software reads scanned laser etchings to trace the origin of a part, including machine and spindle.
LAPSYS sends data from each module to the upper MES system to let managers visualize systems. Plus it analyzes big data for myriad different tasks within a Plan-Do-See Cycle. Plan tasks include scheduling, process engineering, program creation and simulation …
… and “do” tasks tool changeover guidance, consumable part ordering, updating software and updating manuals, and See tasks include traceability, operation monitor, quality control management and error analysis. By unifying the management of the Plan-Do-See Cycle, Fuji makes it possible to achieve even smarter production.
Fuji’s LAPSYS allows remote monitoring for unified management of data for each machine and each line. This makes it possible to monitor progress and machine status as well as other important indexes such as alarm frequency. In addition, remote operation allows access to the application that is displayed on the machine operation panel, making it is possible to edit and check data. For preventive maintenance, data saved in the database is analyzed. This makes it possible to predict machine faults or errors before they occur — reducing machine downtime to a minimum.
FUJI turns the machining of a part into process perfection. When engineers contact FUJI, the part to be machined is analyzed by engineers with vast experience in process and manufacturing engineering. With the largest install base at the major automotive manufacturers, FUJI engineers apply their experience with the FUJI machines that are built for automation from the ground up. These highly accurate machines employ built-in robotic automation, in-process auto gauging for quality control, and are engineered with the finest FUJI custom workholding, all from one source. This allows FUJI engineers to guarantee takt time, cycle time and CPK with turnkey and run-off solutions that are built for lean manufacturing. Using less manpower and more automation, FUJI machines produce the highest quality parts most efficiently and reliably. FUJI solutions are supported by factory-trained American engineers 24/7.
To learn about FUJI automation, visit the manufacturer’s IMTS Booth #339059 or www.fujimachine.com.
Filed Under: IoT • IIoT • Internet of things • Industry 4.0
Tagged With: fuji
Lisa Eitel
