Gap Filler Pads Are Reinforced for Stability
By atesmeh | April 7, 2010
Fujipoly announced the availability of Sarcon GR-HF gap filler pads. These thermal interface materials are manufactured with a hardened top surface as well as a reinforced nylon mesh layer. The added reinforcement and less tacky surface treatments are said to dramatically reduce tearing, elongation and damage during complex assembly and rework operations. These characteristics also make the TIM suitable for applications that require intricate die-cutting. Depending on the selected formulation, Sarcon GR-HF exhibits a thermal conductivity up to 2.8 W/m°K and a thermal resistance as low as .67°Cin2/W. This flame retardant gap filler pad is manufactured in sheets up to 200 mm x 300 mm with thickness options from 1.0 mm to 5.0 mm.
Fujipoly
732-969-0100, www.fujipoly.com
