Gardner Denver Thomas recently unveiled its newly developed 380 series variants: 380CE32 (115/60/1), 380CS32 (100/50/60/1), and 380CUU32 (230/50/1) (coming soon). These oil-less single WOB-L® piston units can be used for pressure or vacuum operation. They are engineered to be used for pressure or vacuum operation and to be versatile and reliable for a wide array of market applications, from general to specific, including medical, laboratory, food and beverage, or industrial.
Units are RoHS, REACH compliant and include an integral 9 blade cooling air flow fan, conventional foot mount design, corrosion resistant wetted parts, and quality die-cast aluminum components. Supplied standard is a capacitor, capacitor insulator boot, and intake filter.
Key Features
- 380CE32 (115/60/1) is UL approved and provides an open flow of 1.2 cfm (34.0 l/min) and can operate up to 100 psi (6.9 bar) continuously as well as a continuous maximum vacuum up to 89 percent of local barometer
- 380CE32 (115/60/1) weighs 9.7 lbs (4.4 kgs) and measures (L x W x H) 6.94” (176.4 mm) x 5.14” (130.6 mm) x 6.73” (170.8 mm)
- 380CE32 (115/60/1) features acceleration at 100 psi (6.9 bar) at 115V 60Hz measured in the “Y” axis is only 0.28 g
- 380CS32 (100/50/60/1) provides an open flow of 1.0 cfm (28.4 l/min)/1.2 cfm (34.0 l/min) and can operate up to 60 psi (4.1 bar) continuously as well as a continuous maximum vacuum up to 89 percent of local barometer
- 380CS32 (100/50/60/1) weighs just 9.95 lbs (4.5 kgs) and measures (L x W x H) 8.40” (213.3 mm) x 5.14” (130.6 mm) x 6.73” (170.8 mm)\
- 380CS32 (100/50/60/1) features acceleration at 60 psi (4.1 bar) at 100V 50/60Hz measured in the “Y” axis is only 0.18 g and 0.26 g respectively; sound levels measure 50 dB(A) and 53 dB(A) at 60 psi (4.1 bar) at 100V 50/60Hz respectively
