Universal Hydraulics International is introducing a range of UH Series gear pumps to complement the existing piston pump line offered through the Duplomatic label.
Produced in Italy by a leading component manufacturer, the basic line consists of a 3-piece design with an extruded aluminum body fitted with cast iron covers. The gear sets are specifically designed to reduce noise levels while offering low pulsations and high efficiency.
Locally stocked product will cover three series with parallel keyed shafts and SAE ports. They are also available in double and triple pump configurations.
All series are also available in both pump and motor configurations with European flange mounting, specialty shafts and outboard bearing configurations.
Additional special order 200 series products include:
• Special gear designed “SILENT” series for industrial plants, fork trucks and platform lifts.
• Heavy duty all cast iron “Hercules” series for high duty mobile applications.
• Flow dividers with or without rest valves
www.uhiltd.com
Filed Under: Bearings, Hydraulic equipment + components
