ASEPTICplus gearmotor features an IP 69K-rated DAS motor with a smooth-bodied, hygienic design to perform reliably in high pressure, high temperature washdown conditions found in the food processing industry. The motor has a smooth surface without recesses.
Since there is no place for bacteria or contaminants to hide, this allows thorough and efficient cleaning. Plus, the totally enclosed non-ventilated motor prevents contaminants from being spread by air flow. The gearmotor has stainless steel components such as blanking plugs, breather valves, screw plugs and output shafts. Special coatings and sealants are also used, including a three-layer epoxy paint that is heat-cured after every layer, as well as EPDM rings and double sealing with FKM on the output side.
SEW-Eurodrive
www.seweurodrive.com
Filed Under: Motion control • motor controls, Motors (gearmotors)
