Gearmotors enhance material handling energy efficiency
By Frank Tobe | March 11, 2016
Energy efficiency is an ever growing concern and a focus point in the manufacturing and material handling portions of the supply chain industry, not only to reduce cost and time, but also to help protect the environment.
NordGearmotors, electric motors, speed reducers and ac vector drives play key roles in improving the energy efficiency of material handling operations. For example, NORD Gear has a two-stage bevel series—the SK92.1 and SK93.1—with gear efficiencies up to 97%. These helical bevel gearmotors can deliver 30% energy savings. Typical right angle worm reducers range in efficiency from 40 to 90% depending on size, ratio and output speed.
The two-stage bevel drives are available in a range of ratios. Features include UNICASETM, a quiet, leak-free housing design, along with wear-free infinite life gearing.
Installation, for replacement or other need, involves using the company’s worm replacement footplate and universal shaft. The footplate, which drops into all standard worm mounting footprints, is available with either threaded or through holes and an optional extended design.
NORD Drivesystems
www.nord.com
Filed Under: Motors (gearmotors)
Tagged With: nord
Bodine now offers 60 new hypoid PMDC gearmotors
Design and selection of induction and permanent magnet ac electric motors for efficiency
With embedded magnets, compact gearmotors offer wide speed range
Gearmotors on the move: Driving AGVs
