Pepperl+Fuchs introduces the VBA-2A-G10-E2L-1M-2V1-W AS-Interface Module. This single module provides two outputs, enabling it to provide one output to two devices. Each output is completely powered by the auxiliary black flat cable. This enables the G10 to deliver up to 2 A per output and up to 4 A per module.
Many standard, modified, and custom G10 versions are available to support virtually any AS-Interface application need. Standard versions include 2 in (one M12 pigtail), 2 in (two M12 pigtails), 2 in (two M8 pigtails), 2 in/1 out (two M12 pigtails), and 2 out (two pigtails).
AS-Interface is an open, multi-vendor technology designed to reduce the complexity and associated costs of connecting conventional inputs and outputs, analog transducers, and safety devices to the dominant PLCs on the market. With an installed base of about 24 million field nodes worldwide, AS-Interface is the most trusted low-level and safety networking technology available.
Pepperl+Fuchs
www.pepperl-fuchs.us
Filed Under: Factory automation, I/O modules, CONNECTIVITY • fieldbuses • networks • gateways, PLCs + PACs
