If you know harsh conditions, then you know its effect on assembly wear and tear. From poor lubricant retention results and frequent downtime to part failure — worn bearings cost time and money. That’s GGB designed DX 10. It’s a tribological solution engineered for environments where high loads, shock, heat and abrasive contamination would typically cause traditional bronze, bi-metallic and roller bearings to fail. The bottom line —DX 10 saves time and money.
Better wear performance
Reduced downtime and maintenance
Lower operational costs
Reduction in warranty claims
GGB’s completely machinable bearings — available with pin-intended surfaces — have a highly resistant polymer surface for excellent abrasion, chemical, and erosion resistance. They’re designed for:
Wide temperature fluctuations
High load capacity
High pU capabilities
Filed Under: Bearings
