Are you in need of a solution that can withstand extreme temperatures without forfeiting on performance? The number of applications that operate under extreme temperatures is on the rise and so is the demand for solutions that can withstand them. GGB’s new solution, PyroSlide 1100 high-temperature powder metal bearings, are designed to not only meet these expectations, but exceed them. PyroSlide 1100 offers high temperature resistance-up to 800°C/1472°F-with better corrosion and wear resistance with low friction properties.
Advantages of GGB’s PyroSlide 1100:
Specialized for high-temp applications
Built for applications that need to operate under extreme temperatures and loads while providing superior corrosion resistance.
Low friction, High wear resistance
Low coefficients of friction eliminate the need for lubrication while reducing wear and extending service life.
Maintenance-free
Ideal for applications requiring long service life without regular maintenance or operating conditions with little to no lubrication.
Filed Under: Bearings
