GHz Bandwidth Transceiver Socket Suits Wafer Level BGA
By atesmeh | December 18, 2009
Ironwood Electronics has recently introduced a new high performance BGA socket for 0.5 mm pitch 51 pin BGA. The SG-BGA-7154 socket is designed for 4mm x 4mm x 0.8 mm package size and operates at bandwidths up to 10 GHz with <1dB of insertion loss. The contact resistance is typically 20 milliohms per I/O. The socket connects all pins with 10 GHz bandwidth on all connections. The socket is mounted using supplied hardware on the target PCB with no soldering, and uses smallest footprint in the industry. The smallest footprint allows inductors, resistors and decoupling capacitors to be placed very close to the device for impedance tuning. The socket also incorporates a new quick insertion method so that IC’s can be changed out quickly. The application of the socket is to verify the function of IC in a development system specifically all currently used UMTS (Universal Mobile Telecommunications System) bands with its different regional frequency requirements in Europe, Asia, North America and Japan. The pin self inductance is 0.15 nH and mutual inductance of 0.025 nH. Capacitance to ground is 0.01 pF. Current capacity is 2 A per pin.
800-404-0204, www.ironwoodelectronics.com
