Gigabit Ethernet I/O Cube
By Design World Staff | June 12, 2009
The PowerDNA PPCx-1G Gigabit Ethernet I/O Cube is available in two basic models ‚— a 3-I/O layer (5-slot PPC5-1G) or a 6-I/O layer (8-slot PPC8-1G).  The GigE Cube offers high speed relative to the standard Cubes but remains compatible with all 30+ UEI I/O board types.
The 6-layer model (PPC8-1G Cube) can provide up to 150 analog inputs, 192 analog outputs, 288 digital I/O, 48 counter or quadrature channels, 72 ARINC-429 channels and 24 Serial or CAN-bus ports. The Framework software provides a comprehensive, easy to use API that supports all popular programming and operating systems such as Windows, Vista, Linux, and most real-time operating systems (e.g., QNX, RTX, RT Linux). In addition, the product is fully supported by LabVIEW, MATLAB/Simulink, DASYLab, or any application that supports ActiveX, OPC or Modbus TCP control.
United Electronic Industries
www.ueidaq.com/GigE-Cube
Filed Under: Ethernet — cables • hubs • switches, I/O modules, Networks • connectivity • fieldbuses
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
Avnu Alliance launches global TSN Certification program
Hardened multi-speed mega PoE injector for diverse infrastructure applications
EKI-7000 Series Firmware Revision makes network management more secure
