Glob top epoxy meets NASA low outgassing specifications
By Mike Santora | November 26, 2018
masterbond-UV-curing-adhesiveMaster Bond EP17HTND-CCM is a new single component epoxy that is not premixed and frozen. It is more convenient to handle, apply and store than typical two component glob top systems. This black, heat curable compound has a flowable paste consistency suitable for glob top, chip coating and bonding applications. EP17HTND-CCM meets NASA low outgassing specifications and is serviceable from -80° to +600°F [-62°C to +316°C]. This adhesive forms high strength bonds to a wide variety of similar/dissimilar substrates such as metals, ceramics, plastics, composites and various circuit board materials.
EP17HTND-CCM is thermally conductive and electrically non-conductive even upon exposure to hostile environmental conditions. EP17HTND-CCM has a high volume resistivity of more than 1015 ohm-cm at 75°F and over 1012 ohm-cm at 400°F. Its thermal conductivity is 9-10 BTU•in/ft2•hr•°F [1.4423 W/(m•K)] at 75°F. Also noteworthy is its ability to resist many chemicals including acids, bases, salts, fuels, oils and many solvents.
Formulated for various electronic applications, EP17HTND-CCM cures readily in 1-2 hours at 350°F [175°C] with a relatively low exotherm upon curing. It can be dispensed from a syringe, either manually or with an automatic dispenser. Master Bond EP17HTND-CCM is available for use in common size syringes ranging from 10 to 30 cc. For storage simple refrigeration at 40-45°F is recommended.
Master Bond High Temperature Resistant Adhesives
EP17HTND-CCM is a one part, heat cured epoxy that meets NASA low outgassing specifications. This high temperature resistant adhesive offers a great flow profile for glob top applications.
Master Bond
www.masterbond.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Adhesives • epoxies, Fastening + joining • locks • latches • pins
Tagged With: masterbond
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
