The universal input switching power supply model series GT-41052 is a versatile wall plug in power supply with input from 90-264VAC 50-60Hz and factory configurable outputs from 5V to 48VDC outputs and a max power of 15W continuous output. An IP52 version is now available.
IP52 per IEC60529:2001 specifies that the GT-41052 series is Protected against dust – limited ingress (no harmful deposit) as well as Protected against direct sprays of water up to 15 deg from the vertical. The low leakage, low ripple, and high efficiency design is suitable for most applications requiring DC power and may have exposure to outside elements.
Common applications for this ruggedized model include medical equipment, utility monitoring equipment, portable equipment and instruments, mobile communication devices and telecom equipment, and as a power source for Li-Ion battery chargers. Customized enclosure colors, housing designs, output cord types and lengths, as well as customized packaging available upon request. Made in USA option available.
The power supply can be supplied with customer designated output plugs, many of which are stocked at GlobTek New Jersey USA and Suzhou China locations. The power supply complies with IEC 60950-1 and has certifications by UL (North America), C-Tick (Australia/New Zealand), Iram (Argentina), BSMI (Taiwan), CB (Worldwide), CCC (China), Demko (Europe), NRCAN (Canada), Spring (Singapore), SIQ (Europe), Gost (Russia), and UkrSEPRO (Ukraine).
GlobTek
www.globtek.com
Filed Under: Power Electronic Tips
