Graphite Metallizing Corporation announces the availability of GRAPHALLOY® stainless steel cam followers for wet or submersible applications. These stainless steel cam followers are corrosion resistant and survive wash down and steam, eliminating the problems experienced with traditional cam followers.
GRAPHALLOY® cam followers do not contain oil or grease to harden, burn up, contaminate or wash away. They are designed to handle moderate loads and speeds of up to 100 RPM and provide reliable performance in temperatures up to 750‚°F (400‚°C).
Typical applications include bakery and industrial ovens, steel mill equipment, glass plants, conveyors, kilns, stokers and substrate dryers. GRAPHALLOY® cam followers also perform well in low temperature environments of -100° F (-75‚°C).
GRAPHALLOY®, a graphite/metal alloy, is a uniform, solid, self-lubricating material. GRAPHALLOY® cam followers will not deform under load, maintain dimensional stability and provide a constant low coefficient of friction for improved wear. GRAPHALLOY® cam followers are especially suitable in applications where lubrication or maintenance tasks are cumbersome, difficult or impossible to perform.
www.graphalloy.com
Filed Under: Bearings, MECHANICAL POWER TRANSMISSION
