MultiVoltage lithium batteries target material handling equipment
By Lee Teschler | July 2, 2021
Patent-pending MultiVoltage technology enables the battery to charge at double its output voltage, which cuts charging time in half and makes opportunity charging a more accessible option with simplicity and ease of use for the operator.
Patent-pending MultiVoltage technology enables charging at double the batteries’ output green cubesvoltage, halving the charge time and increasing productivity. Applicable to the material handling market, Green Cubes Technology’s MultiVoltage battery completes a full charge in less than one hour and is offered in 24/48 V, 36/72 V and 48/96 V combinations.
Green Cubes has deployed over 200 MultiVoltage batteries across these three different voltage combinations. It is common for high use and high capacity batteries, such as a large 48-V battery, to be charged with two cables to increase the charge current. The MultiVoltage battery utilizes single connector 4/0 cabling in a charge port configuration, which delivers cost efficiencies and minimizes the chance of cable damage over traditional fast charging with dual cables. In addition, due to the lower insertion and extraction forces of the single connector equipment, operators appreciate the MultiVoltage systems over their dual cable counterparts.
“The ability to opportunity charge is a key feature of Li-ion batteries’ value proposition for material handling equipment,” said Anthony Cooper, General Manager of Green Cubes’ Motive Group. “MultiVoltage SAFEFlex batteries accommodate an even faster charging time which widens the performance gap between Li-ion and Lead Acid Batteries. Our class 2, 36-V products, have been extremely popular for Reach Trucks because they are very highly utilized and recognize the benefits.”
Other than the battery configuration itself, the MultiVoltage battery uses standard chargers and requires no changes to the equipment. Lithium SAFEFlex is the integration of lithium-iron=phosphate cells, electronics, packaging and a software platform that was designed specifically for the rugged requirements of material handling. The advanced mechanical packaging meets the impact forces of a large forklift and the rugged automotive-grade Battery Management System (BMS) makes Lithium SAFEFlex the most reliable lithium battery for the material handling industry. With MultiVoltage technology, a quick coffee or lunch break can be used to charge a battery, keeping material handling equipment in full utilization.
Green Cubes Technology, 121 East Blvd., Kokomo, IN 46902, 502.416.1060, greencubestech.com/
Filed Under: Batteries, MOTION CONTROL
Tagged With: greencubestechnology
