Greenkote reports surge in anti-corrosion coating orders for metal fasteners
By Michelle Froese | February 10, 2021
Greenkote, a global provider of advanced anticorrosion metal coatings, announced a major expansion of production capacity at its headquarters facility in Brook Park, Ohio. The expansion comes in response to an upsurge in demand for corrosion protection on environmentally-exposed metal fasteners and hardware in several industries.
Greenkote anti-corrosion coating equipment. Learn more here.
“I don’t know if climate change may be a part of it, but we’re seeing notable increases in anti-corrosion coating orders for all kinds of different metal parts that are exposed to the elements,” said Greenkote CEO, Mark Gore. “The orders are coming from a range of sectors, including automotive, rail, electric power distribution, wind power generation, and others. These are all applications that have fasteners, fixtures and other metal hardware exposed to long-term outdoor atmospheric corrosion.”
Greenkote can be applied to a broad range of metal parts, from threaded fasteners to stamped and cast pieces, in sizes from 0.2 to 78 inches. The company provides anti-corrosion coating services for construction, automotive, rail, utilities, and many other industries in which parts are exposed to weather or harsh and corrosive environments.
“It’s also possible that we’re getting more than our share of this business because of a couple other factors,” added Gore. “Number one: Greenkote coatings are actually diffused into the metal surface, making them damage resistant, longer-lasting and better-performing than older treatments such as galvanizing and paints. Another factor is eco-friendliness. Many other coating processes involve acids and other polluting chemicals, so their use is increasingly restricted by environmental regulation. But, as the name implies, Greenkote is uniquely benign to the environment.”
Gore added that installation of the additional Greenkote coating equipment in Brook Park has been completed and the facility is now fully operational with significantly expanded capacity.
Proprietary Greenkote coatings have been replacing several older anti-corrosion processes, such as galvanizing, hot-dip, sherardizing, and metal flake. In addition to increased corrosion protection, Greenkote technology provides superior adhesion, longer wear, and more conformal coverage, which allows its use on complex geometries such as small threaded parts.
Greenkote also eliminates metal failures caused by hydrogen embrittlement, an intrinsic problem with many traditional coatings. Greenkote is applied by a patented zinc-based dry thermal diffusion process that requires no hazardous chemicals and produces no toxic byproducts. Consequently, it is uniquely friendly to humans and to the environment.
Tagged With: greenkote
