Clippard’s GV series valves offer a bubble tight design with high flow rates of 38 scfm @ 50 psig; 67 scfm @ 100 psig. These compact 2-way and 3-way valves are offered in 1/4” NPT and 3/8” push-quick ports along with a cartridge mounted version. With Clippard’s versatile 15/32-32 nose thread, a large variety of buttons and valve actuators can be used with the GV stem operated valves. The GTV series are toggle valves with panel mounting capabilities. The outlet port on all GV valves can be easily positioned to any orientation for mounting convenience.
Clippard GV-GTV Series High Flow Poppet Valves
• Will accept a variety of manual, air pilot, electrical or mechanical actuators
• Design flexibility and fast response
• Stainless steel stems and springs for long life and corrosion resistance
• Corrosion-resistant series also available
Clippard
www.clippard.com
Filed Under: Pneumatic Tips
