    • Subscribe!
Flame-retardant plastic enclosures mount on standard DIN rails
By Lee Teschler | July 2, 2020
The 1597DIN family of UL94-V0 flame-retardant plastic enclosures mount to standard IEC/EN 60715 35-mm DIN rails for applications such as industrial control equipment, automation, equipment management and monitoring, HVAC controllers and distributed IoT equipment. The family consists initially of four sizes: 2, 4, 6 and 9 standard 17.5-mm module widths. All sizes have two mounting positions for the terminal blocks, maximizing I/O availability and giving hammondheadroom for future expansion if required. There are two horizontal PCB mounting slots in the body and two stand-offs in the base for component or PCB mounting. Plain, vented, knock out and slotted terminal covers are supplied separately and can be mixed and matched in the bodies as required. Primarily designed to accept PCBs is a slimline 22.5-mm wide, 118-mm deep and 90-mm high polycarbonate control box with ventilated sides and a shaped front panel.
All units feature simple no-tool snap together assembly and correspondingly easy disassembly for access to the internal components or PCB when required. The bodies are ventilated on the top and bottom faces and feature a recess in the front panel for mounting identification labels or other graphics.
The bases are molded in dark grey PPO (polyphenylene oxide) with a polystyrene DIN rail mounting clip and the main enclosure body is RAL 7035 light grey polycarbonate.
Hammond Electronics Pty Ltd, 11 – 13 Port Road, Queenstown SA 5014, Australia, www.hammondmfg.com
You may also like:
  • How do sensors make a building more comfortable?
  • Understanding 3DP: Selecting the right process and material for you
  • How to Find the Perfect Enclosure for Your System
  • What are DIN rails for motion applications?
Filed Under: Industrial automation, Cabinets • enclosures • control panels
Tagged With: hammond
    • Subscribe!
